Rotor Posted October 6, 2010 Share Posted October 6, 2010 Hi My P38 fr r/h window wont reset, it just keeps running when the lift button is pressed and causes the gear on the mechanism to ratchet like a machine gun! Any ideas? Ta Rotor Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 6, 2010 Share Posted October 6, 2010 The gear mechanism is worn out. The easy cure is to change it. The difficult cure is to take it out, cut off a strip containing the few teeth that haven't been used, grind off the same number of worn teeth, then weld the strip of unused teeth into their place. Most people pay the money and change the complete unit. Some people change the motor as well, but I suspect most don't bother. HTH Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted October 7, 2010 Share Posted October 7, 2010 just had this problem myself replaced the regulator with a new one i got on ebay for £35 delivered easy job to do only 4 rivets hold the unit in now no more annoying beep every time i start the car Rob Quote Link to comment Share on other sites More sharing options...
