Jimmy Two-Jacks Posted October 17, 2010 Share Posted October 17, 2010 Hi, I know I ask a lot of questions but here goes. On a 90 the angled channel section brackets that fix the rear wing to the underside of the tub infront of the rear wheel arch what are they called so I can do a search for some new ones? Also do they just bolt through the floor and to the bottom tab/return of the wing as they appear to or is this a former bodge? Cheers James Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2010 Share Posted October 17, 2010 just called body stays IIRC, attach with a bolt/nut to the bottom flange on the panel.item 5 on page 872 you need this 90 parts book in .pdf format. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted October 18, 2010 Author Share Posted October 18, 2010 just called body stays IIRC, attach with a bolt/nut to the bottom flange on the panel.item 5 on page 872 you need this 90 parts book in .pdf format. Thanks Ralph, downloaded and saved. Cheers James Quote Link to comment Share on other sites More sharing options...
