davidstoncold Posted October 26, 2010 Share Posted October 26, 2010 took my 52 plate for mot today first failure in 3 years of owning it. it needs a brake pipe changing front to back . the test bloke says i can put a repair piece in to replace corroded bit. what size of pipe will i need and is there a kit available to replace the corroded piece. i have no doubts i can do it its just the sizes of pipw needed and fittings to do the job im stuck with ,, Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted October 27, 2010 Share Posted October 27, 2010 I bought a brake pipe flaring tool some years ago from Halfords when I had a Morris Marina (now that was a maintenance challenge) but only used it once. You might find the following helpful although it might be cheaper overall to buy a replacement brake pipe. www.abbeypowertools.co.uk/car-repair-tools/brake-repair-tools/showitem-5558@37870.aspx Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 27, 2010 Share Posted October 27, 2010 Fittings *should* be M10 metric, they are on my '98. Standard 3/16" copper/cupro-nickel pipe is available by the reel at motor factors, as are flaring tools and fittings. I wouldn't replace a section of pipe, do the whole thing then it's done. Quote Link to comment Share on other sites More sharing options...
ChrisW Posted October 28, 2010 Share Posted October 28, 2010 Most proper motor factors will make you a brake pipe with fittings and flare the ends for you for a few pounds, use a bit of string to measure the length of the old one. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted October 28, 2010 Share Posted October 28, 2010 TBH.....If your unsure of what you need then IMHO you need to get someone that knows what there doing with the brakes/pipes to help you. Its not something you want to get wrong...is it ? Quote Link to comment Share on other sites More sharing options...
