Peter Posted June 13, 2006 Share Posted June 13, 2006 Does anyone know the diameter of the electical wire of a standard 9.5 12v winch such as warn or superwinch ? I.E the earth and live wires to the battery. BTW anyone use anderson connectors with their winch (if so which rated amp one do they use - and why) Cheers Peter Quote Link to comment Share on other sites More sharing options...
JST Posted June 13, 2006 Share Posted June 13, 2006 what are anderson connections? if they are the socket mountings similar to Si R (X-Eng) jump start set then i have used these for a demountable winch system and got the biggest ones i could from VWP (i think) not sure on Ampage though. ref the cable i have used 35mm2 std and welding cable in the past. Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2006 Share Posted June 13, 2006 Anderson power connectors the 350amp [grey] for a winch at the minimum Quote Link to comment Share on other sites More sharing options...
