del Posted November 6, 2010 Share Posted November 6, 2010 Next problem in my engine change saga is the fan . Ive put a 200 tdi in my 90 fitting a set of p38 double fans and a thermo switch thats operated with a thermal probe fitted it the top hose. When the truck has stopped the fan keeps running obviously sensing the hot water after about 10 mins i ended up disconecting the fan thinking by the time the waters cooled down its going to run the battery down,anyone got any suggestions? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 6, 2010 Share Posted November 6, 2010 The feed to the relay (through the sensor) should be fed from an ignition-switched source. Some setups have a controller that keeps it on for a minute or two after switch-off in order to combat heat-soak, but this would require extra electronics and isn't strictly necessary Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted November 6, 2010 Share Posted November 6, 2010 I bet that you sensor is in the top hose? Hot water rises!! If you want it to be powered "unswitched" you should put the sensor in the bottom hose! Why do you need it running after the engine has stopped anyway? The 200TDi with a viscous fan didn't have that luxury! I'd switch it through the ignition. Cheers Peter Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted November 6, 2010 Share Posted November 6, 2010 The feed to the relay (through the sensor) should be fed from an ignition-switched source. Exactly Quote Link to comment Share on other sites More sharing options...
del Posted November 6, 2010 Author Share Posted November 6, 2010 sorted Quote Link to comment Share on other sites More sharing options...
