simon Posted June 15, 2006 Share Posted June 15, 2006 Guys, has anyone fitted an Xeng Disc brake conversion to the LT95,apparently I was supposed to by a LT230 speedo casing and shaft but when I took mine off the rear of the LT95 it has 8 bolts and the LT230 one I have is only 6, the casing is a dirrent diamenter so I can't eb=ven re drill the casing holes and the shaft in my LT95 is a short 6spline shaft and the LT230 is a long 20+ spline shaft. I have also been told that one off a early 110 with a 4speed box will fit so if anyone has one or can shed light on my quest then please help me as I have so far spent £200+ and still without a handbrake. Please let me know. thanks simon Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted June 15, 2006 Share Posted June 15, 2006 Speak to SimonR, i'm sure he'll know what to do and be more than helpful Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted June 15, 2006 Share Posted June 15, 2006 I'm sure you need the one off an LT95 from a 110. Quote Link to comment Share on other sites More sharing options...
Wattle Posted June 15, 2006 Share Posted June 15, 2006 I have one fitted to my 110 with an LT95 box, I didn;t need to change the speedo housing, so I suppose that is the housing you want. I hope this has been of some help. Phil Quote Link to comment Share on other sites More sharing options...
