rocky Posted November 18, 2010 Share Posted November 18, 2010 Hi, i am going to put a gutter mounted spotlight bar, with the lights wired into my main beam of my 90 tdci, could someone kindly suggest the best route for the cables (as unobtrusive as possible)and where to drill a hole in the roof. Regards, rocky Quote Link to comment Share on other sites More sharing options...
Frax Posted November 18, 2010 Share Posted November 18, 2010 If it was me I would drill a hole at the top front edge of the drivers door, pull door seal down a bit first at keep as close as posible to top edge, feed wires through and down inside piller behind cover. Regards Frax Quote Link to comment Share on other sites More sharing options...
dazwell24 Posted November 18, 2010 Share Posted November 18, 2010 i have mine through the roof gutter drain hole then pushed them through the door seal and run down behind the trim to the dash looks neat and tidy and no holes drilled just silicon where u push them trough the door seal HTH dazwedll24 Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2010 Share Posted November 18, 2010 I used a plug/socket on the roof just above the B post door pillar, no trapped wires in door shutline then. Quote Link to comment Share on other sites More sharing options...
Mocha Bear Posted November 18, 2010 Share Posted November 18, 2010 I have drilled the roof just becide the light bar, and come in behind the trim as above with a rubber gromit. I have a roof bar with lights for sale if your looking? was only fitted for a couple of months then fitted a cage, so is in brilliant condition! Mocha Quote Link to comment Share on other sites More sharing options...
rocky Posted November 18, 2010 Author Share Posted November 18, 2010 Many thanks for the replies. I did want to put lights on an A bar but the insurance co., wouldn't agree so it will have to be a roof bar or rack. Regards, rocky Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2010 Share Posted November 18, 2010 don't see why our chosen location for the lights is of any concern to insurers, unless they don't insure 'A' bars. loads of R's have additional lights on those type of bars. Quote Link to comment Share on other sites More sharing options...
