del Posted December 4, 2010 Share Posted December 4, 2010 are defender 200 tdi and disco tdi dipstick lenghts the same? i think ive got a disco dipstick in my defender block ,the oil reading goes way past the min max levels -any ideas- Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted December 4, 2010 Share Posted December 4, 2010 It's quite common for the tube to come loose and drop down in to the sump by 10-20mm or so. It's clamped in place by an olive and nut. If the nut loosens just a bit the tube will slip through the olive, lowering the dipstick in to the oil. Undo the nut and carefully remove the tube - pull the nut, before the tube. you don't want the olive being pulled off and dropped in the sump. You should see where the olive shoud sit - and where it is currently. Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2010 Share Posted December 4, 2010 I posted the LR tech bulletin on here about incorrect oil dipstick readings, a search should fine it. Quote Link to comment Share on other sites More sharing options...
