ricky tango Posted December 6, 2010 Share Posted December 6, 2010 Right looking on paddocks it states hub seal inner and hub seal outer ? I have a rrc k reg and looking at my hub it only has one seal at the back behind the inner wheel bearings were the outer seals only fitted To some hubs ? Quote Link to comment Share on other sites More sharing options...
longlandy Posted December 6, 2010 Share Posted December 6, 2010 Cant really remember, have seen on some and not on others so I aint saying nothing. What I will say is be carefull with paddocks as they seem to be selling total carp quality spares, I threw away the last order I recieved from them. Quote Link to comment Share on other sites More sharing options...
ricky tango Posted December 6, 2010 Author Share Posted December 6, 2010 Ok well I've clicked oe parts only so hopefully not got a load of cacka coming my way , just spoke to a mate who said check mine again that there's not two of them because there in close proximity to eachother and so could look like 1 seal Quote Link to comment Share on other sites More sharing options...
dave 1 Posted December 6, 2010 Share Posted December 6, 2010 rick when we took them off u only had 1 its the same as mine Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 6, 2010 Share Posted December 6, 2010 Which hubs do you have? flat ended or dome ended? Dome ended have 2 seals, an inner and an outer. Flat ended have a hub seal and a halfshaft seal. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted December 8, 2010 Share Posted December 8, 2010 The ABS style axles (with flatter half shafts) have the diff to hub oil seal within the stub axle and running on a journal on the half shaft, this replaces the seal you see beneath the head of the halfshaft on older axles. The other oil seal runs on the inside of the hub and is the hub to exterior seal. Later models had a revised seal with the vertical lip missing, the lip keeps mud away form the seal surface. The seal should be 4mm below the hub surface if it has the lip, I prefer to fit this type but you also need the check the running surface of the stub axle, if it's scored or rusty it may well leak. Quote Link to comment Share on other sites More sharing options...
