Frogland Posted December 18, 2010 Share Posted December 18, 2010 This might sound a bit daft,but i'm not sure weather my 1998 110 def has got a handbrake 'on' light on the dash panel.Should it have one ? if so why isn't it working ? where should i look ? I've never thought about it before because everything is so spartan in a defender Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 18, 2010 Share Posted December 18, 2010 Remove the handbrake gaiter. If you see a small switch activated by the handbrake handle and your light doesn't work, then you have a problem. If there is no switch evident then the warning light is behaving as it should HTH Mo Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted December 18, 2010 Share Posted December 18, 2010 It should have the position on the dash, but it's probably not wired and you won't have a bulb or switch. I believe it was/is only county spec vehicles that get the switch fitted at the factory. It's certainly not hard to add a switch yourself, if you want to. there's a post on here about fitting one. edit: tech archive post here Quote Link to comment Share on other sites More sharing options...
