stripy Posted December 19, 2010 Share Posted December 19, 2010 i am having a problems removing the crankshaft gear off the end of the crank, i have made up a puller but as the gear is so close to the casing there isnt much room behind it for anything substantial behind it. is there a puller made for this job. or anyone got any ideas ? i have tried heating it up with no sucsess.....it is realy stuck fast. Quote Link to comment Share on other sites More sharing options...
stripy Posted December 19, 2010 Author Share Posted December 19, 2010 sorry forgot to say defender 90 200 tdi Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2010 Share Posted December 19, 2010 the puller bolts should screw into the 2 threaded holes in the front face of the gear, there is a special tool LRT-12-078 & LRT-12-031 both a very expensive though. some Tdi timing kits include the bolts/puller for this job. Quote Link to comment Share on other sites More sharing options...
stripy Posted December 19, 2010 Author Share Posted December 19, 2010 hi ralph i dont supose you know what the thread size is on the gear ? iv'e got a timing pin kit with puller.....but it dosent do the gear puller just found one on difflock £148.37 plus......wont be spending that much Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 19, 2010 Share Posted December 19, 2010 Stripy, I've just had a look and the holes on the crankshaft sprocket are M5. Mine was very tight but I persevered with 2 big flat blade screwdrivers, gently prying opposite sides, but it was tight all the way along the woodruff keys. A favour too if I might ask - I need a couple of pics of your power steering pump set up, if you're not too busy HTH Mo Quote Link to comment Share on other sites More sharing options...
stripy Posted December 19, 2010 Author Share Posted December 19, 2010 nice one mo just front piccy or pipe at rear Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 19, 2010 Share Posted December 19, 2010 Both if poss, Stripy Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2010 Share Posted December 19, 2010 hi ralph i dont supose you know what the thread size is on the gear ? iv'e got a timing pin kit with puller.....but it dosent do the gear puller just found one on difflock £148.37 plus......wont be spending that much threads are as Mo says -- M5, I got my timing kit off ebay. you'll have to obtain 2 long M5 bolts & adapt your existing puller. Quote Link to comment Share on other sites More sharing options...
stripy Posted December 19, 2010 Author Share Posted December 19, 2010 cheers ralph....and for mo it wont upload a rear view but ill try something else Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 19, 2010 Share Posted December 19, 2010 Ok stripy, many thanks You can email it if that helps mate. Address is in my profile. Mo Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 19, 2010 Share Posted December 19, 2010 threads are as Mo says -- M5, I got my timing kit off ebay. you'll have to obtain 2 long M5 bolts & adapt your existing puller. May be better Ralph, to use 3 bolts as there are 3 holes pitched around the sprocket. HTH Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2010 Share Posted December 19, 2010 May be better Ralph, to use 3 bolts as there are 3 holes pitched around the sprocket. HTH Mo Yes that would be better, forgot there was 3 holes. Quote Link to comment Share on other sites More sharing options...
Somethingwitty Posted December 20, 2010 Share Posted December 20, 2010 Get some thick steel plate, drill a centre hole and 3 holes for the M5 bolts and then use a suitably large bolt and nut to draw it all off - protecting the crank nose with a sacrificial bit of plate - I made a puller for mine, took a long time too since I pinched the steel from work and forgot it's origin - Rolled Homogeneous Armour - unsurprisingly pretty bloody hard! Wasn't pretty but worked, anything else is less than certain and may damage something expensive. Quote Link to comment Share on other sites More sharing options...
stripy Posted December 21, 2010 Author Share Posted December 21, 2010 hi something what you sugest is what i am going to do, just waiting to get hold of the m5x100 bolts then i shall make a heath robinson puller Quote Link to comment Share on other sites More sharing options...
