V8RRC Posted June 24, 2006 Share Posted June 24, 2006 Hi All, I need the part number for the front prop flange bearing in the borg warner transfer box! This is the bearing that supports the viscous coupling. (89 Range Rover) I have the old part number which is RTC6025 if that helps Cheers, Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2006 Share Posted June 24, 2006 EPC shows you have the correct number already. Quote Link to comment Share on other sites More sharing options...
V8RRC Posted June 24, 2006 Author Share Posted June 24, 2006 Hmmm...... Thats what I thought as that is the number in my RR parts book! But I have been to Craddocks site to order the bearing & it says wrong part number. O well looks like I will have to ring them to order it.. Cheers for looking Regards, Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2006 Share Posted June 24, 2006 Ring your local main dealer, tell the parts person you only have a old number from that they should be able to find a current number or go with the bearing to the nearest bearing/engineering supplier,again they should be able to match it. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 24, 2006 Share Posted June 24, 2006 Microcat hows it as the same too: As does the downloadable Bearmach parts finder utility (quite cool that.... available here) Quote Link to comment Share on other sites More sharing options...
V8RRC Posted June 25, 2006 Author Share Posted June 25, 2006 Thanks for your help guys! I have found a online supplier of bearings & seals & there prices seem ok! They can be found here http://simplybearings.co.uk I have just ordered my bearing from them. Thanks again, Quote Link to comment Share on other sites More sharing options...
