paulk Posted January 13, 2011 Share Posted January 13, 2011 Rear passenger windows will not operate. Isolation switch is off. I have seen solution to problem for Series 1 on this forum. Is the solution the same for Series 2 or does the relay come into play? Quote Link to comment Share on other sites More sharing options...
nicks90 Posted January 14, 2011 Share Posted January 14, 2011 yes, same windows essentially - just like the leaky sunroofs! Quote Link to comment Share on other sites More sharing options...
paulk Posted January 15, 2011 Author Share Posted January 15, 2011 Where can I find the rear window ecu in the series II? Quote Link to comment Share on other sites More sharing options...
ches Posted January 15, 2011 Share Posted January 15, 2011 no ecu for the rear windows on disco 2. operated by the BCU/IDM and a lift relay. check fuse 13 in the passenger fusebox Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 16, 2011 Share Posted January 16, 2011 no ecu for the rear windows on disco 2. operated by the BCU/IDM and a lift relay. check fuse 13 in the passenger fusebox On a DII, the BCU plays no part in switching the Rear Electric Windows, they're switched directly by the switches. The only part the IDM plays, is to provide the earth to the Rear Window Relay's coil when the ignition is on. Here's the wiring diagram - . Quote Link to comment Share on other sites More sharing options...
jiginc Posted January 17, 2011 Share Posted January 17, 2011 Point of interest; The window drive motors are the same for both the D1 and D2 BUT reversed. Left on a D1 fits the right door on a D2 Right on a D1 fits left on a D2. Strange is it not. jiginc Quote Link to comment Share on other sites More sharing options...
