5122 Posted January 14, 2011 Share Posted January 14, 2011 Maybe this topic has been up before, but I am planning to upgrade the brakes on my 1997 Discovery tdi. As standard its got solid discs, 4 pot calipers and a single pipe brake line system. Upgraded calipers (to vented) requires twin pipe input and won't work without plumming in pipes and a different brake master cylinder (not keen on that). I've heard about conversions usings Defender 110 brake calipers (larger than disco), disco discs and 110 pads (larger), but is this a straight swap? Will it work? Would love to hear from anyone with experience of this! Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 15, 2011 Share Posted January 15, 2011 I know a couple of guys who have done it no problems. Nothing needs to be machined, modified or fabricated. It's also a favourite on 90's. There's a guy round here who sells second hand parts that will swop the calipers for nothing as the Disco caliper is worth more to him than a 110 one. Quote Link to comment Share on other sites More sharing options...
5122 Posted January 15, 2011 Author Share Posted January 15, 2011 Thanks for your reply! I've since 'discovered' that although its a straight swap, the 110 caliper pistons are larger and will therefore require the brake master cylinder to work harder resulting in increased pedal travel. Don't really want to get into changing that too. Got to stop somewhere and get the damn thing on the road at some point soon. Sounds like a nice upgrade especially as I do quite a lot of mountain driving (auto) and my brakes reguarly overheat. I'm bringing the car out to Italy, where I got comformaty issues when it comes to registring the car, so I guess its not worth it at this point. Thanks again! Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted January 16, 2011 Share Posted January 16, 2011 My mate bought a spacer kit for his callipers and fitted vented disks. The casting is identical on single and dual circuits and the vented callipers all have spcers fitted. Kit form the bay IIRC Also the 110 callipers I have don't look wide enough for vented disks, but I may be wrong. I bought them for a RRC though and they don't have dual circuit so not much use. Quote Link to comment Share on other sites More sharing options...
5122 Posted January 16, 2011 Author Share Posted January 16, 2011 You are right, I could fit a spacer, but the advice is not to split the calipers (not sure why, but think that has something to do with the seal). I've decided to keep things simple and just overhaul my existing calipers with a repair kit as upon inspection, at least two pistons where sticking which would explain some of the overheating I've had. Quote Link to comment Share on other sites More sharing options...
africanpete Posted January 18, 2011 Share Posted January 18, 2011 Does anyone know if there is a conversion for the Discovery 2? the rear brakes in particular as mine are shot, calipers and pads will need replacing, disks are ok but might consider changing them if there is an upgrade available here... Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 18, 2011 Share Posted January 18, 2011 You are right, I could fit a spacer, but the advice is not to split the calipers (not sure why, but think that has something to do with the seal). I've decided to keep things simple and just overhaul my existing calipers with a repair kit as upon inspection, at least two pistons where sticking which would explain some of the overheating I've had. Have a look at this thread http://forums.lr4x4.com/index.php?showtopic=63169 , more a cost issue than a safety issue Quote Link to comment Share on other sites More sharing options...
andy2986 Posted January 18, 2011 Share Posted January 18, 2011 I've just finished this conversion on my Disco. So far the results are stunning! The peddle doesn't have any more travel, so result there. The pads are a lot bigger, and although they are still bedding in they have far more bite than before. I appreciate that my old brakes might have not been at there best but they had just past an MOT. I've also replaced all the copper brake pipes on the rear axle with braided hose, the hose runs from the t piece by the diff and travels along the axle and goes into the calliper using a banjo fitting, like on a motor bike. Also I've used braided hose on the fronts and done away with the small copper pipe by going direct to the calliper with another banjo style fitting. So far so good, going to take it to a friendly Mot place tomorrow and have them put it on there brake tester and check there all working OK and also see if he is happy with what I've done. Andy Quote Link to comment Share on other sites More sharing options...
panther-uk Posted February 26, 2012 Share Posted February 26, 2012 Does anybody have the part and where to get them in the UK I've got a 300TDi 97 Auto Disco, no ABS, brakes passed on the MOT, but at 60%, so since I need to sort this out, thought I'd upgrade at the same time, as sometimes tow. Thanks for any help Simon Quote Link to comment Share on other sites More sharing options...
