Tibout Posted January 16, 2011 Share Posted January 16, 2011 hi guys just a quick question. when cleaning the sedimenter, when you remove the top bolt and remove the whole bowl will fuel from the tank keep coming out from the pipe or it's the same as the fuel filter? thanks thierry Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted January 17, 2011 Share Posted January 17, 2011 I'm told it won't syphon out, especailly if the tank is almost empty. Quote Link to comment Share on other sites More sharing options...
Tibout Posted January 17, 2011 Author Share Posted January 17, 2011 yeah that's what i've been thinking but my tank is half full Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted January 17, 2011 Share Posted January 17, 2011 Haynes gives the impression that it will but I haven't found that to be case. There's still a lot of diesel in there so you have to put up with a wet arm but it doesn't syphon from the tank (I've not done it with more than about half a tank though). You could always stick a clean container underneath if it does. Quote Link to comment Share on other sites More sharing options...
davek0974 Posted January 17, 2011 Share Posted January 17, 2011 Mine was ok with half a tank. Stick a plastic bag over the bowl before you break the seal, then the fuel will run Into the bag not your armpit. Quote Link to comment Share on other sites More sharing options...
Tibout Posted January 18, 2011 Author Share Posted January 18, 2011 thganks guys i will get a bag under it hopefully not with a hole in it Quote Link to comment Share on other sites More sharing options...
