minimaquinas Posted January 19, 2011 Share Posted January 19, 2011 hi i have 110 county and when i use the rear wash wipe it nearly always blows its fuse but its mainly if it doesnt park itself properly can anybody shed some light as i am fast running out of 10 amp fuses cheers in advance brian Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2011 Share Posted January 19, 2011 the motor shaft might be partly siezed in it's tube, there's not much else to go wrong, it a single speed with auto park, or a part of the wiring where it pass the door hinge line is damaged & possobly shorting out on the door or body. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 19, 2011 Share Posted January 19, 2011 Do you have a rear door mounted spare wheel? may be catching the wiper arm putting load on and stalling the motor Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted January 19, 2011 Author Share Posted January 19, 2011 cheers western i will check the wiring and maybe squirt a bit of oil down the shaft and hopefully it may fix it and pete i do have a door mounted spare wheel but it clears the wiper I THINK lol i will also check it tho thanks lads Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2011 Share Posted January 19, 2011 If the spare tyre is touching the wiper arm, you can adjust the 3 nuts so the wheel/tyre sits slightly further away from the wiper arm/shaft. IIRC I used some 3 in 1 light oil on my rear wiper when I had a similar fault [but not popping the fuses] I removed the motor from the door so the oil would run around the shaft & not just drip out onto the floor. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 20, 2011 Share Posted January 20, 2011 The motor itself is officially 'non-repairable' or whatever words they use. So you may have to get another. Quote Link to comment Share on other sites More sharing options...
Turnip Posted January 20, 2011 Share Posted January 20, 2011 That wiper motor which looks simple - is actually quite complicated! I rigged up one on mine where there wasnt one before and it gave me all sorts of fun and games! The bit i didnt bank on is that it has "regenerative earth braking" according to Joeseph Lucas the prince of darkness! What this means is that you shove a 12 v pulse down the wire to start it and then the 12 v permanent feed carries it full the full stroke to park. What I didnt know is that at the end of the stroke a little nylon cam raises a contact and put the motor to earth to stop the motor sharply in the correct parking position. If this cam is cracked - and a lot are, you can have all sorts of shorting issues. Interestingly - if you dont have the earth braking bit connected, when the window is very wet, the wiper just keeps on going and going! Quote Link to comment Share on other sites More sharing options...
