Peterla Posted January 25, 2011 Share Posted January 25, 2011 I is the middle of summer in Australia and my Air conditioner just stopped working. I am a refigeration mechanic so know my way around AC but it is not a mechanical fault. My Fan on the evaporator runs and my condenser fans are also working. The clutch on my compressor is not engaging. Hi temperature water sensor OK and High presuure refigerant switch OK. Looks like it maybe a thermostat problem that is in the Dash!!!! Can anyone help with an electrical drawing before I go to the effort or pulling out my dash. This will assist me with fault finding and not to much down time. Peter Quote Link to comment Share on other sites More sharing options...
Riz Sauvage Posted January 25, 2011 Share Posted January 25, 2011 Hey Peter, 200's with aircon over here aren't that common, hopefully someone will be able to supply a diagram, but if you're in a fix, and need a quick solution, the cluch is engaged by simply supplying it power, so as a temp bypass fix, you could run a live to it direct, via a switch. Regards, Si Quote Link to comment Share on other sites More sharing options...
ches Posted January 25, 2011 Share Posted January 25, 2011 what MY is the 200? Quote Link to comment Share on other sites More sharing options...
Peterla Posted January 25, 2011 Author Share Posted January 25, 2011 Thanks Si, I have already done this but I bypass all the saftey options! High pressure and high water temperaturte. Would be great to get a wiring diagram before I start so I know what I am looking at. Pete Quote Link to comment Share on other sites More sharing options...
teabag Posted January 26, 2011 Share Posted January 26, 2011 This is a drawing of a 300s a/c it may help you. Quote Link to comment Share on other sites More sharing options...
