Cartman Posted January 27, 2011 Share Posted January 27, 2011 Just wondering and I am sure I saw a post somewhere to say that the 200/300tdi filter without the water sensor fitting at the base will spin onto a TD5 fuel filter head. Anyone found this to be the case? Reason being OEM LR/Bosch tdi filters are a lot cheaper than TD5 ones if you are not bothered with the water sensor. Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 27, 2011 Share Posted January 27, 2011 should do. according to my filter book they have the same thread. as a side note, the same filter for the tdi fits a case tractor - and the case dealer sells them for £19 + vat, needless to say, i'm now selling loads to the local farmers at nearly a 1/4 of the price Quote Link to comment Share on other sites More sharing options...
nino Posted January 27, 2011 Share Posted January 27, 2011 i was getting filters for my 200tdi defender from halfords 3.50 each for fuel and oil filter with trade card isnt bad but they dont list for td5 as i wanted a fuel filter for one of thoes as well my td5 dont have the water sensor in the bottom either Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 27, 2011 Share Posted January 27, 2011 They are the same physical fitting but I seem to recall seeing somewhere that the Td5 one has finer filtration probably due to the EUI's being a bit more particular about poo in the fuel than the old Tdi sludge pump, hence the silly price for the Genuine parts. New Td5 injectors are quite expensive too, not sure if it is an economy I would make Quote Link to comment Share on other sites More sharing options...
Cartman Posted January 27, 2011 Author Share Posted January 27, 2011 If that is the case Boggy then I will stay with the specific TD5 one! Ordered Coopers for now as the genuine was +£30....wouldn't go down to ****part for something like this. Quote Link to comment Share on other sites More sharing options...
sharpy1980 Posted January 27, 2011 Share Posted January 27, 2011 I needed a fuel filter for my 200tdi 90 in a hurry and had a service kit for the wifes td5 disco standing by so I robbed the Mahle fuel filter and fitted it to the 90 and it worked a treat for a month before I started having fuel starvation issues, the filter was full of sludge and the only thing I can put it down to is finer filtration and the 90 tank having crud in it that don't normally get stopped by the normal filter, needless to say I flushed the tank before changing back to the right filter. Quote Link to comment Share on other sites More sharing options...
