carlosbeldia Posted February 2, 2011 Share Posted February 2, 2011 Land Rover asks ACEA B2 for 300 TDi. However, my vendor is telling me their Rimula Rx4 (ACEA E3) exceeds ACEA B2 requirements, simply because E is after B. Is this correct? I think and understand B and E protocols are completly differents codes for applications. Quote Link to comment Share on other sites More sharing options...
fozsug Posted February 2, 2011 Share Posted February 2, 2011 A/B : gasoline and diesel engine oils E : Heavy Duty Diesel engine oils Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted February 2, 2011 Author Share Posted February 2, 2011 Yes, I know, but E exceeds B needs? Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2011 Share Posted February 2, 2011 Yes, I know, but E exceeds B needs? so then it meets B requirements & is OK for your engine. Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted February 2, 2011 Author Share Posted February 2, 2011 But I don't know, There is a Rimula R4 meeting E7. Howeveer, my common oil 5w40 A3/B3 really looks different, kind of more fluent...... In ACEA parammeters, they mention E as a completely different oil than B, and the description applies for different engines (low rpm, big displacement, great times of stationary RPM) Quote Link to comment Share on other sites More sharing options...
fozsug Posted February 2, 2011 Share Posted February 2, 2011 But I don't know, There is a Rimula R4 meeting E7. Howeveer, my common oil 5w40 A3/B3 really looks different, kind of more fluent...... In ACEA parammeters, they mention E as a completely different oil than B, and the description applies for different engines (low rpm, big displacement, great times of stationary RPM) Rimula RT4 is a 15w40 so will be thicker than youre usual 5w40. I use 15w40 in my 300tdi with no problems at all, so i would say that it will be fine Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2011 Share Posted February 2, 2011 300tdi should have engine oil meeting or exceeding RES.22.OL.PD-2 or CCMC PD-2 or API CD 15W/40 for ambient temp range from -10 to +50 degree C. refer to the oil specification bit in this link hopefully it will answer your question. Quote Link to comment Share on other sites More sharing options...
Mack Posted February 3, 2011 Share Posted February 3, 2011 ACEA specs do not relate to viscosity and "exceeding" does not meen is better for your engine. Same for transmission oils: GL-5 is not better than GL-4. There are exceptions though. http://www.motul-lubricantes.com/eftm/definicion_normas_ACEA_motor_liviano.pdf http://www.lubrizol.com/EuropeanEngineOils/RelativePerformanceToolIntro.html Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted February 4, 2011 Author Share Posted February 4, 2011 However, Land Rover updated oil specs for 300 Tdi, asking for ACEA A3/B3 and superior. Is ACEA E7 superior to A3/B3?. I've been analizing ACEA guidelines finding they are no compatible in test engine, ACEA asks for different parammeters. Seeing this, I think they are not fully interchangeable, am I right? Quote Link to comment Share on other sites More sharing options...
