Fossy31 Posted February 8, 2011 Share Posted February 8, 2011 Hi all, I have tried a search but couldn't come up with the answer, so here goes... Central locking has been working fine for years until I go to the disco after it being sat without a battery for a week, I reconnected the battery and all was fine for a few days until.... Now when I press the fob to lock it, it locks all doors then immediately unlocks all doors and then locks and unlocks continuously until you press the unlock button. If you try and lock the drivers door with the key it would do exactly the same. In the short term so I can actually lock the car I have removed the link from the actuator to the drivers lock and now have to lock all doors manually, obviously the alarm is not armed so I'd quite like to fix it. I was going to buy a new drivers actuator to try, until I saw the price! Does anyone have any ideas what I could try before splashing out on a new actuator? Cheers Foss Quote Link to comment Share on other sites More sharing options...
fozsug Posted February 8, 2011 Share Posted February 8, 2011 You could try oiling up the mechanism and giving the actuator a good squirt of WD40, but by youre symptoms and what you have eliminated , sounds like its the actuator cycling, which as you have already said needs replacing. Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted February 8, 2011 Share Posted February 8, 2011 Replacement lock actuator from Maplins, fits and works perfectly £9.99 http://www.maplin.co.uk/door-lock-motors-12304?ordercode=YD78K Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 8, 2011 Share Posted February 8, 2011 It sounds like it is not detecting a door shut properly. Is it worth checking the switches? Cheers Peter Quote Link to comment Share on other sites More sharing options...
teabag Posted February 8, 2011 Share Posted February 8, 2011 Try adjusting the actuator on it's mountings, there's a fine line either it locks or unlocks or 'bounces' so slacken and move the actuator one way or the other, there's only a few milimetre each way but thats enough. Quote Link to comment Share on other sites More sharing options...
Fossy31 Posted February 9, 2011 Author Share Posted February 9, 2011 Ok thanks guys, I will try adjusting the acctuator tonight and hope its that. Peter, when you say check the switches, do you mean the ones which also control the interior lights? If you do i'm pretty sure that both passenger side and rear switches do not work, and i dont think they ever have, interior lights dont stay on when you leave these doors open?? Quote Link to comment Share on other sites More sharing options...
Fossy31 Posted February 9, 2011 Author Share Posted February 9, 2011 Tried the actuator is lots of different positions and it still does the same. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 10, 2011 Share Posted February 10, 2011 What I meant was that in my experience with my Disco, if a door wasn't shut properly the locks would cycle. I was just wondering if there was a dodgy switch or connection giving a similar effect? Cheers Peter Quote Link to comment Share on other sites More sharing options...
