dicsosfa Posted February 11, 2011 Share Posted February 11, 2011 hi i think 1 of my uj's on the front prop on my 300tdi disco has gone ( horrible tinkering noise on acceleration and under load) just wondered if the 200 and 300's have the same front prop as i can get 1 from a 200tdi from my mate that he has spare that had 2 new uj's fitted a few months ago but never used for a fiver also if i got rid of the rubber doughnut on the rear what bits would i need and how hard would it be to do the job ? Roy Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted February 12, 2011 Share Posted February 12, 2011 To get rid of the rubber doughnut you need to change the diff flange to a 4 bolt, simple enough job. Remove prop, take the doughnut alighnment spigot thingy out the centre of the flange (might be a bit stuck in there, but it is just pushed in. I needed heat and slide hammer). Then undo the big nut in the middle and its done :-). May be worth replacing the seal while your there if your diff leaks. As for the front prop, I am 99% sure it fits, give it a measure is the easiest way to do it. HTH Quote Link to comment Share on other sites More sharing options...
martifers Posted February 12, 2011 Share Posted February 12, 2011 Would also need a 200 disco rear prop (4 bolt to replace the 300's 3 bolt) once you've changed the flange as above. As for front props, I see no reason why they would be different, both double ended 4 bolt with same stud pattern. Quote Link to comment Share on other sites More sharing options...
axlechorus Posted February 12, 2011 Share Posted February 12, 2011 I would be very suprised if they are not the same knowing Land Rovers liking to carry parts over from model to model. There are a couple of kits avaliable now that include the parts needed to convert from a 3 bolt to a 4 bolt system. Off the top of my head they were about £20 to £30 depending on the supplier but may well have changed since I last looked. Quote Link to comment Share on other sites More sharing options...
