Disco-Ron Posted February 20, 2011 Share Posted February 20, 2011 Hi all..... i currently have RR classic rear springs on my truck, as they're the tallest 'standard' springs there are, nice and soft too.... i use my truck for ALRC rtv's, and i need soft springs, however, i have found that even with these springs i don;t quite have enough height when the truck has all the gear on board.... So, what i require is taller springs, but with roughly the same spring rate, i don;t want much firmer, as that will limit articulation...... there don;t seem to be many tall and soft springs available..! Any ideas..?? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 20, 2011 Share Posted February 20, 2011 You really need to know what compressed spring length you want when fully loaded. So, load up the truck and head off to your local weighbridge and find out what each axle weighs. Then, armed with this data, subtract 150kg for the front axle and 100kg for the rear and take a look at the tech archive for spring options and have a play with Trev's spring calculator. Easy! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 20, 2011 Author Share Posted February 20, 2011 If you understand such things, which i don;t........LOL Whats the crack with local weighbridges, there's one a mile away, but i have no idea if i can just drive in, and onto it or what...??? Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted February 20, 2011 Share Posted February 20, 2011 AIUI, you can just turn up at a 'public weigh bridge' and expect to have your vehicle weighed. I guess there will be a charge, but I doubt is is exorbitant. You can find a list of public weigh bridges on your county council's web site, which gives the contact numbers so you can call ahead and ask what the charges will be. On the other hand, there are lots of companies who operate private weigh bridges and I'm sure in most cases, asking the operator nicely, and slipping them a few beer vouchers, will have the desired result. Nick. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 21, 2011 Share Posted February 21, 2011 If you understand such things, which i don;t........LOL Whats the crack with local weighbridges, there's one a mile away, but i have no idea if i can just drive in, and onto it or what...??? Beer tokens usually work Alternatively, call Gwyn Lewis and explain your dilemma...... Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 21, 2011 Share Posted February 21, 2011 If your happy with the springs as they stand apart from the ride height, why not just use some spacers to give the extra height. Pete. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 21, 2011 Author Share Posted February 21, 2011 Thanks all...... pete, i have already fitted 20mm spacers, hence why i've now decided i need longer springs.... and probably shocks too, as i'm only running standard length at the moment.... Quote Link to comment Share on other sites More sharing options...
