p38rr Posted February 24, 2011 Share Posted February 24, 2011 Please help I am trying to fit delay wipers to an early 90 and have the switch PRC7370 and the delay unit AMR2341. I also need the wiring loom PRC8295 but it seems it is N/L/A. Does anybody have the diagram so i can make the loom myself? I have searched all the forums but cant sem to get anywhere Quote Link to comment Share on other sites More sharing options...
Litch Posted February 24, 2011 Share Posted February 24, 2011 I was in the same boat last year when I discovered the loom was no-longer available. I just used the wiring diagram out of the back of the owners manual and the Haynes to work out the differences and make up the replacement. I expect they are on-line somewhere but someone will have to post a link, haven't you got either of these publications yourself? Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 http://forums.lr4x4.com/index.php?showtopic=927 did this to my 110, Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 24, 2011 Author Share Posted February 24, 2011 http://forums.lr4x4.com/index.php?showtopic=927 did this to my 110, Yep saw this earlier before I posted but it dosen`t tell me how to make the loom!! Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 photo of loom section from britcar's website, you should be able to match the wire colour codes with the Defender wiring diagrams, doubt you'll be able to excatly match the rubber moulded plugs/sockets though. Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 24, 2011 Author Share Posted February 24, 2011 Trouble is some of the connectors are hidden and I cant see the colours of the wire on them!! Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 additional wiring info for front intermittent wipers. item 83 is the front wiper delay relay, for ident of it's connections refer to my link above. the Green [G] wire goes to 15 amp fuse [ignition controlled 12v feed. item 97 is the front wash/wipe stalk & it's associated connctions item 98 is the front wiper motor iyems 100 & 101 are front & rear screen wash pumps. hth Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 24, 2011 Author Share Posted February 24, 2011 Spot on, Ta muchley Will give it a go tomorrow Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 25, 2011 Author Share Posted February 25, 2011 Well I drew a blank on this today as the wiring colours are different on the switch I have so Im back to square 1. It looks like the only way forward is to copy a loom that someone else has! Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2011 Share Posted February 25, 2011 I'm guessing your vehicle has the spring return flick wipe when pressed down, if so to gain intermittent wipe, you need to buy the later wiper stalk as in my link, otherwise the system will not work, the later stalk has a 6 wire conection whereas the existing stalk has 5 wire connections. Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 25, 2011 Author Share Posted February 25, 2011 Got the later switch but the wiring colours dont line up Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2011 Share Posted February 25, 2011 that's strange, as mine just connected together, is the new stalk a genuine LR part or from another supplier ? & how many wires in to it's multiplug ? http://www.lrseries.com/shop/product/listing/9970/PRC7370-WASH-WIPE-DELAY-SWITCH-STALK.html?search=prc7370&page=1 Quote Link to comment Share on other sites More sharing options...
p38rr Posted February 25, 2011 Author Share Posted February 25, 2011 Its the correct switch all be it a britpart one! The connector will fit with the existing loom its that I dont have the additional loom needed and the colours on the new switch dont correspond to the manual or the diagrams you sent me!! Quote Link to comment Share on other sites More sharing options...
western Posted February 26, 2011 Share Posted February 26, 2011 (edited) might be a 300tdi wiper stalk, but AFAIK the wiring colours are the same, I'll check my 300tdi wiring info, in the morning wash/wipe switch with intermittent facility [not flick wipe, early stalk] 6 wires green ---- 12v feed to intermittent relay/front screen wash pump white/green --- to intermittent relay yellow/light green --- to intermittent relay blue/light green --- to wiper motor light green/black --- to intermittent relay red/light green --- to wiper motor Edited February 26, 2011 by western wiring colour info added Quote Link to comment Share on other sites More sharing options...
