lynall Posted February 25, 2011 Share Posted February 25, 2011 Im trying to work out how much lift my 90 has had Ive measured from the floor to the wing top and its 42.5 inchs and centre of wheel to wing top which is 29 inchs Can someone measure theirs and let me know? Also front prop slider splines are sticking out by 1.5 inchs any recomendations for the correct prop or supplier? Many thanks Lynall Quote Link to comment Share on other sites More sharing options...
Mack Posted February 26, 2011 Share Posted February 26, 2011 The distance between the axle and axle stop is 84+/-15 mm. Quote Link to comment Share on other sites More sharing options...
lynall Posted February 26, 2011 Author Share Posted February 26, 2011 Mack you are my hero for the weekend Ta Lynall Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted February 26, 2011 Share Posted February 26, 2011 The prop obviously isn't right. Several people sell spacers or you may find another LR product has a longer prop. If it's lifted a lot then look into a TD5 Cardan joint at the gearbox end. Quote Link to comment Share on other sites More sharing options...
lynall Posted February 26, 2011 Author Share Posted February 26, 2011 I assume when you say axle stop you mean bump stop? If so i have just measured between axle and bottom of axle bump stop 75mm and axle to bottom of chassis 135mm. So by my reckoning its had a 2 inch lift does that sound right? As for the prop i have serviced the car today and noticed damage to the chassis in a couple of places and the sump pan, both in line with where the prop u/js are so its probably had a major failing and any old prop has been stuck on. Lynall Quote Link to comment Share on other sites More sharing options...
lynall Posted February 26, 2011 Author Share Posted February 26, 2011 Actually just having a rethink and i reckon it could be std height as from the floor to the roof top its 2 metres which ties with what i can find on the web Lynall Quote Link to comment Share on other sites More sharing options...
