dazwell24 Posted March 10, 2011 Share Posted March 10, 2011 hey guys and gals can any one help me will a p38 zf auto wxyz switch work on my disco2 td5 auto box and if weston happens to know a part no awsome many thanks dazwell24 Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2011 Share Posted March 10, 2011 P38 XYZ switch is STC2944 or UHB100180 or STC4452 depending on original vehicle chassis number. D2 Td5 auto awitch is UHB100190 can't say if the P38 switch will work on your vehicle, simply because I don't know. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted March 11, 2011 Share Posted March 11, 2011 Sorry again for letting you down - 2hrs earlier and you could have had it.Have you checked the loom where it goes over the top of the transfer box ? If thats OK it may be worth taking your switch off,drilling the rivets out and dismantling it.If its not too corroded you may be able to repair it.The early P38 switch wont fit - I've got one of those,and I dont think the later one does but I'm not 100% sure. Quote Link to comment Share on other sites More sharing options...
dazwell24 Posted March 11, 2011 Author Share Posted March 11, 2011 P38 XYZ switch is STC2944 or UHB100180 or STC4452 depending on original vehicle chassis number. D2 Td5 auto awitch is UHB100190 can't say if the P38 switch will work on your vehicle, simply because I don't know. Quote Link to comment Share on other sites More sharing options...
dazwell24 Posted March 11, 2011 Author Share Posted March 11, 2011 thanks very much weston for part numbers ur a true asset to the forum Quote Link to comment Share on other sites More sharing options...
dazwell24 Posted March 11, 2011 Author Share Posted March 11, 2011 Sorry again for letting you down - 2hrs earlier and you could have had it.Have you checked the loom where it goes over the top of the transfer box ? If thats OK it may be worth taking your switch off,drilling the rivets out and dismantling it.If its not too corroded you may be able to repair it.The early P38 switch wont fit - I've got one of those,and I dont think the later one does but I'm not 100% sure. cheers ally am just putting her up on the ramp to have a look now will badger you later for ur knowledge many thanks dazwell24 Quote Link to comment Share on other sites More sharing options...
