Tibout Posted March 11, 2011 Share Posted March 11, 2011 hi does anyone have the instruction on how to adjust the starter motor on a TD? mine keep engage and does'nt dis-engage. thanks in advance thierry Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 11, 2011 Share Posted March 11, 2011 There's no adjustment of the starter motor that I'm aware of. Les. Quote Link to comment Share on other sites More sharing options...
Tibout Posted March 11, 2011 Author Share Posted March 11, 2011 there's one on mine les. it's with the lock nut and the screw. to adjust the the engagement lever, there's 2 arrows one on the casing and one on the pin(screw). it should be adjusted to the correct clearence. but i don't have the instruction i know it's in a manual somewhere Quote Link to comment Share on other sites More sharing options...
MUDisGood Posted March 14, 2011 Share Posted March 14, 2011 As Tibout said u can adjust in that way but correct throw out and spring reset float need to be correct and trial and error will take time. have had similar prob before. Remove it and cleaning with plenty of WD40 sorted it nicely! Dan Quote Link to comment Share on other sites More sharing options...
