trt1617 Posted March 30, 2011 Share Posted March 30, 2011 been looking through a few posts on here and there is mention of people useing a rear winch to do center pulls as well any one got and pics of this set up i could have a look at??? thinking of king cabbing my truck and fitting my now front winch to the rear as im on the look out for a new front one and was wondering if it could be mounted and used as both as i would see a rear being more useful but a center could be handy to have on occasions. any one have any idea how powerful a winch would have to be to pull a 90 back on its wheels from having a lay down???? Quote Link to comment Share on other sites More sharing options...
redrodant Posted March 30, 2011 Share Posted March 30, 2011 been looking through a few posts on here and there is mention of people useing a rear winch to do center pulls as well any one got and pics of this set up i could have a look at??? thinking of king cabbing my truck and fitting my now front winch to the rear as im on the look out for a new front one and was wondering if it could be mounted and used as both as i would see a rear being more useful but a center could be handy to have on occasions. any one have any idea how powerful a winch would have to be to pull a 90 back on its wheels from having a lay down???? 8 or 9000lbs should pull most landies uprigh. Quote Link to comment Share on other sites More sharing options...
Orange Posted April 4, 2011 Share Posted April 4, 2011 A 5000lbs winch would pull most upright, but it depends how deep and sticky the mud is. I have an EP9 for a centre winch and isn't struggling to cope with my lardy 90... As for using the rear winch as a centre, try running the line to a snatch block and back to the cage. We used that technique several times before biting the bullet and fitting a centre winch too... Start each event with a couple of small strops attached to the cage, or weld on a couple of extra hook points... Hth Adrian Quote Link to comment Share on other sites More sharing options...
sitrials Posted April 5, 2011 Share Posted April 5, 2011 This is how I've done mine: Basically i've layed the winch (GOODWINCH TDS9.5) on its side and made a loop for the cage. and it works really well! used it alot during our first LRS challenge. plus keep its down to only 2 winches and in a lower class. I do have a fair lead you can pass a hook through which i got off a mate who had it custom made! seen below. Have fun! Quote Link to comment Share on other sites More sharing options...
trt1617 Posted April 6, 2011 Author Share Posted April 6, 2011 This is how I've done mine: Basically i've layed the winch (GOODWINCH TDS9.5) on its side and made a loop for the cage. and it works really well! used it alot during our first LRS challenge. plus keep its down to only 2 winches and in a lower class. I do have a fair lead you can pass a hook through which i got off a mate who had it custom made! seen below. Have fun! so you can pass the rope through what ever way ya wanna pull the truck? this looks like the way forward just need to find out if its still as usefull if the top fairlead is mounted a bit further back than yours as i want to king cab mine to keep some room inside Quote Link to comment Share on other sites More sharing options...
zardos Posted April 6, 2011 Share Posted April 6, 2011 so you can pass the rope through what ever way ya wanna pull the truck? this looks like the way forward just need to find out if its still as usefull if the top fairlead is mounted a bit further back than yours as i want to king cab mine to keep some room inside I've used my rear through the cage on my van side and found it useful in stopping falling over and bringing you closer to punches. So on a king cab it should be fine. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted April 6, 2011 Author Share Posted April 6, 2011 I've used my rear through the cage on my van side and found it useful in stopping falling over and bringing you closer to punches. So on a king cab it should be fine. Exactly how did ya pass it through the cage? as in where did it exit from the truck? Thanks Quote Link to comment Share on other sites More sharing options...
zardos Posted April 6, 2011 Share Posted April 6, 2011 Exactly how did ya pass it through the cage? as in where did it exit from the truck? Thanks Follow the dent in the body What's one more dent to the 26 billion others Quote Link to comment Share on other sites More sharing options...
trt1617 Posted April 6, 2011 Author Share Posted April 6, 2011 Follow the dent in the body What's one more dent to the 26 billion others was it passed through the inside of the rear hoop then out over the front to rear roof bar? Quote Link to comment Share on other sites More sharing options...
zardos Posted April 6, 2011 Share Posted April 6, 2011 was it passed through the inside of the rear hoop then out over the front to rear roof bar? Yes Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 6, 2011 Share Posted April 6, 2011 Show's how i did mine. i remove the rear carrier when competeing Quote Link to comment Share on other sites More sharing options...
