willfromsussex Posted April 23, 2011 Share Posted April 23, 2011 Bought a wing mounting kit (angle bits along the top etc) but they came with a couple of these Can't work out where they go, anyone? My car is a 1972. Quote Link to comment Share on other sites More sharing options...
mwgriffiths Posted April 23, 2011 Share Posted April 23, 2011 Are we talking outer wing? If so my guess is that they're for the trailing edge of the wing. If you open the drivers door, looking forward there should be two vertical strips of steel on the bulkhead below where the scuttle panel lies. The one closest to the engine should be longer and should have a seal on it, the smaller one has/had a couple of screw clips. I guess that piece should be attached to that trailing edge of the wing to screw through to the bulkhead. That's pure guesswork though, been playing with the Series the past few days so the Rangie is being neglected I find the huge LR parts catalogue with exploded diagrams more useful than a Haynes manual at times, but I guess its not really worth the money now you're so close Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted April 23, 2011 Share Posted April 23, 2011 That's a possibility, also the front end of the mounting rail is spearate on some RRC, up to where it bends just above the sidelight. Quote Link to comment Share on other sites More sharing options...
mwgriffiths Posted April 23, 2011 Share Posted April 23, 2011 Found it: Group L: Front Wings and and Deck Panel Part number 391317(2) Seems to actually be and extension of the L shaped section that mounts the top of the inner and outer wings. Not sure what it does, its not what i thought it was and not something I've seen on mine :/ P.S. Told you parts catalogues are AWESOME Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted April 25, 2011 Author Share Posted April 25, 2011 Thanks. That seems to be where it goes indeed, but can't see what it does. Only two of the holes seem to line up, but maybe they have 4 holes so the same part can be used on either side of the car. When i google that partnumber this page comes up http://www.lrseries.com/shop/product/listing/871/3569/1/391317-WING-MOUNTING-RAIL-REAR.html?limit=0 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 25, 2011 Share Posted April 25, 2011 Are you sure it doesn't bolt vertically to the bulkhead allowing you to fit the screws in from the hinge side of the door? i.e. the rear most edge of the wing. Quote Link to comment Share on other sites More sharing options...
mwgriffiths Posted April 25, 2011 Share Posted April 25, 2011 Are you sure it doesn't bolt vertically to the bulkhead allowing you to fit the screws in from the hinge side of the door? i.e. the rear most edge of the wing. That was my first thought, my parts manual begs to differ however. I'm still unsure tbh Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted April 25, 2011 Author Share Posted April 25, 2011 hole spacing wrong for that Quote Link to comment Share on other sites More sharing options...
willfromsussex Posted May 8, 2011 Author Share Posted May 8, 2011 pic Quote Link to comment Share on other sites More sharing options...
