Rickspark Posted April 27, 2011 Share Posted April 27, 2011 Hello all, At around £15 for a set of seals, and there are plenty of offer on the web, I'm thinking I will replace these. There are a good few postings suggesting that this will be a waste of time and I should replace the box but £15 vs £250 is making me feel it's worth a try for the cost of a day of my time. Any thoughts would be welcome and does anyone know what size that big nut is? Richard Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted April 27, 2011 Share Posted April 27, 2011 Its normaly wear in the box that makes the seals leak so a new seal might help for a real short time as its a bit softer.....and IIRC the nut is a 41mm HTH Quote Link to comment Share on other sites More sharing options...
gadget Posted April 27, 2011 Share Posted April 27, 2011 The seals failed on mine because the sector shaft had pitted and worn. They are repairable, but if you're looking for the repair to last it's a lot more involved than simply swapping seals. There are two types of seals too. Take your seals out and check which you have before you buy replacements. Quote Link to comment Share on other sites More sharing options...
