stuck Posted April 29, 2011 Share Posted April 29, 2011 Hi all, Brake fluid, very expensive stuff that is only performing a very basic hydraulic function. Can hydraulic oil be substituted? I only ask because I have access to 100's of gallons of hydraulic oil and don't like paying £8 for a little bottle of brake fluid! Quote Link to comment Share on other sites More sharing options...
western Posted April 29, 2011 Share Posted April 29, 2011 NO, if not the correct specification it'll most likely eat the seals or turn them to a black mush, not good for safe braking, it'll cost you more for new seals all round. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 30, 2011 Share Posted April 30, 2011 eat the seals or turn them to a black mush Brake fluid already does that quite well Mo Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted May 1, 2011 Share Posted May 1, 2011 Thing is, it's not performing a 'basic' hydraulic function. The circuit itself may be simple to understand but it's a high performance setup and will cause ordinary fluids to 'boil'. If manufacturers could use something cheaper they would. Added to this as others have stated conventional fluid may eat the seals. It's designed as a system, and chopping/changing fluids & seals will cause no end of grief. (Albeit a system spec'd by accountants and assembled by brummies! :-) ) Quote Link to comment Share on other sites More sharing options...
