300tdi Power steering
At the bottom of the power steering unit there is an arm described as the tie bar (item 9 if this works).
Should there be a bush on this part ?
Part 9 goes through the hole in part 19 at that point but the hole at 19 is about three times the shaft size.
Am I missing something ????
Frax :huh:
NO.
there is just a large hole in that item, no bush was ever fitted. you are NOT missing anything.
item 9 is a tiebar, it's job is to prevent the steering box twisting into or away from the chassis when the steering is moved from the straight ahead position.
Thank you Ralf.
It just looks wrong.
Frax ;)
it's a fairly common question, when owners change steering boxes, I thought there was a bush too, but found otherwise after consulting the parts book. workshop manual.
I know that Land Rover are not known for their tolerances but that is taking it a bit too far.
Frax :unsure:
It could be that both the whole and the spigot have corroded or worn considerably, so instead of being a clearance fit, they're a "cavity" fit instead. Imine certainly had some slack, but it wasn't enormous.
