muddy4x4xfar Posted May 6, 2011 Share Posted May 6, 2011 hi all. im building my td5 110 . im at a point to fit the brakes. iv been looking on microcat which has totally confused me. can anyone give me a diagram of how the brake setup should be on a defender 110 td5 without abs. its got vented front discs, and solid discs on the back. also when looking at microcat it shows whats called a valve brake on some pictures but not all. is this somthing mine will need?? cheers chris Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 6, 2011 Share Posted May 6, 2011 Know the feeling..... Some have a G valve, some a PDWA, and some a four port bias valve... Not sure which is "better" tho Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted May 6, 2011 Author Share Posted May 6, 2011 Know the feeling..... Some have a G valve, some a PDWA, and some a four port bias valve... Not sure which is "better" tho wow thanks for reply but i feel just as muddled up now . Quote Link to comment Share on other sites More sharing options...
western Posted May 6, 2011 Share Posted May 6, 2011 G valve was usually fitted to 90's only. the PDWA unit was discontiued on 110 & replaced by the low fluid level float switch same as 90's have. brake system layout was revised in 1991 IIRC, these 2 pages should help. Quote Link to comment Share on other sites More sharing options...
