des90 Posted June 2, 2011 Share Posted June 2, 2011 I have a promlem with hot starting with MS2 with edis ign-When starting hot the idle rises and falls until the wideband lambda heats up and sets.The engine then runs perfectly at 14AFR.I have played about with the EGO and AE with no success-Anybody got any ideas Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted June 3, 2011 Share Posted June 3, 2011 Sounds like your VE table is a little off, and your idle valve isn't set up correctly. Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted June 3, 2011 Share Posted June 3, 2011 Sounds like your VE table is a little off, and your idle valve isn't set up correctly. A little more info please. You need to explain your perfectly good theory in lay-man's terms. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 3, 2011 Share Posted June 3, 2011 Posting a data log of your starting problem would be very helpful. Quote Link to comment Share on other sites More sharing options...
des90 Posted June 4, 2011 Author Share Posted June 4, 2011 Ok- i'll try to post log -last time i tried to do this it didnt happen for some reason? Quote Link to comment Share on other sites More sharing options...
des90 Posted June 4, 2011 Author Share Posted June 4, 2011 Sounds like your VE table is a little off, and your idle valve isn't set up correctly. I,v been fine tuning the VE table and i,m happy with that and this problem has been happening from the start and any amount of adjustment doesnt seem to change it- but one thing i have noticed is that i,v had to recalibrate the throttle pot twice-I checked it with a multimeter and all seems ok-I wonder if it was sending dodgy signals at idle and that is the problem Quote Link to comment Share on other sites More sharing options...
des90 Posted June 4, 2011 Author Share Posted June 4, 2011 Sounds like your VE table is a little off, and your idle valve isn't set up correctly. Just in case i,v had brain fade-what would you say the rough settings should be for a RV8 idle valve? Quote Link to comment Share on other sites More sharing options...
des90 Posted June 4, 2011 Author Share Posted June 4, 2011 TRIED TO UPLOAD CURRENT TUNE FILE AND IT SAYS I'M NOT PERMITTED TOO!!! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 6, 2011 Share Posted June 6, 2011 Rename it from .msq to .txt and it should allow it. Note the VE table is just for running, the point of interest here is warmup enrichment / IAT correction tables. How bad is your TPS? They're not super precise so +/-10% is fine, if it's hitting the top value randomly then the ECU will go into flood clear mode and not inject any fuel. Quote Link to comment Share on other sites More sharing options...
