Mark Posted June 17, 2011 Share Posted June 17, 2011 Does anyone know the diameter of the steel tube included in the military/land rover snorkel (this one)? ta Mark Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted June 17, 2011 Share Posted June 17, 2011 Does anyone know the diameter of the steel tube included in the military/land rover snorkel (this one)? ta Mark I think its 63mm but I will check when I get home I have got similar one fitted. Cheers J Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2011 Share Posted June 17, 2011 I reckon 75mm [3 inch] inside diameter, can post the Defender fitting info for that part number if you want it. Quote Link to comment Share on other sites More sharing options...
johnseedee Posted June 18, 2011 Share Posted June 18, 2011 I recently fitted one of these. The outside diameter of the tube is about 70mm (measured 70.5mm, but it has a thick "plastic" coating). Do you need the inner as well? If yes, then I'll have to take the top off. A good quality kit in my opinion - but it is the only one I've ever fitted! John Quote Link to comment Share on other sites More sharing options...
Mark Posted June 18, 2011 Author Share Posted June 18, 2011 John, Cheers for that - the od is fine for what I was trying to work out... no need to take the top off. Was basically trying to see if I could swap the top for a different one, but it is looking unlikley. If I were to go for it, I would probably make a new top up completely... Cheers Mark Quote Link to comment Share on other sites More sharing options...
johnseedee Posted June 18, 2011 Share Posted June 18, 2011 Ah - I see, but the standard mushroom top fits on a rubber collar of 77-78mm diameter with a metal clamp. Something like a Donaldson cyclonic filter would probably fit. Have a look at the installation instructions for the LR STC 50265 and you will find some diagrams. John Quote Link to comment Share on other sites More sharing options...
