transfer box front output bearing??
discomikey
trying to remember from when I rebuilt mine....I think you can, and just a quick google for a manual brings me a diagram which i think confirms it. You have to remove the drive flange, and then theres a serperate bearing housing behind it.
Theres a very good sketch in the Haynes manual, which I think is lifted direct from the green bible, IIRC
Yep - take the front prop off the output flange, remove the output flange and undo the six bolts securing the bearing housing to the front of the 4wd housing.
Putting the new bearing in the freezer for a few hours and warming the aluminium housing in the oven at 100oC for 20 minutes immediately prior to refitting will make pressing the new bearing in a doddle.
