Where do the pipes go - RRC ABS Master Cylinder plumbing
task
Having replaced all the rotten parts and stripped all the brake pipes off I'm now left with the headache of trying to fathom out which pipes go where from the ABS master cylinder.
I notice the master cylinder had a number printed above each union but the workshop manual doesn't seem to have any reference to this. It does have a diagram but there looks to be margin for error, not something I want to have on an ABS system!
Any ideas people?
Cheers
not specfic to a CSK RR, but it might help.
item 1 left hand front hose
item 2 right hand front hose
item 3 left hand rear hose
item 4 right hand rear hose
item 5 to 13 as shown on diagram
you should be able to enlarge the diagram to figure out where the pipes fit on the ABS block, hope it helps.
Cheers :)
I'd had a look at that in the manual, should be able to sort something out from that and the pipes that didn't crumble off.
It's just a standard RRC ABS system on the CSK. I might be able to copy the old mans 1994 classic if I get stuck!
