RobotMan Posted July 6, 2011 Share Posted July 6, 2011 As per title I'm looking for the length of the clutch slave rod for a Defender LT77. I suspect I might have used a series part in there. The one I have is 92mm end goes in flush to the outside of the housing once the slack is taken up. This seems wrong to me and leaves next to no pedal on the new clutch. I don't want to have to strip everything out if its simply the wrong rod. I haven't any here to compare against and can't find any info beyond tips for poking the clip back in. Quote Link to comment Share on other sites More sharing options...
western Posted July 6, 2011 Share Posted July 6, 2011 LT77 should be FRC3417 but now FTC3912 pushrod photo here with a measuring stick below it http://www.brit-car.co.uk/product.php?xProd=86561 Quote Link to comment Share on other sites More sharing options...
RobotMan Posted July 6, 2011 Author Share Posted July 6, 2011 LT77 should be FRC3417 but now FTC3912 pushrod photo here with a measuring stick below it http://www.brit-car.co.uk/product.php?xProd=86561 Thanks! Quote Link to comment Share on other sites More sharing options...
BritanniaBoy Posted December 19, 2012 Share Posted December 19, 2012 LT77 should be FRC3417 but now FTC3912 pushrod photo here with a measuring stick below it http://www.brit-car....php?xProd=86561 Hi Western -- was that picture taken by you? If so, would it be possible for you to take an accurate measurement for me? I've got a dilemma, basically I need to know how much longer FTC3192 is than FTC5199 (R380 Td5 pushrod). FTC5199 measures up at about 99mm. If you could let me know what FTC3192 is it'd be greatly appreciated. Many thanks Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2012 Share Posted December 19, 2012 I think it's borrowed for illustration, Td5 R380 pushrod here http://www.brit-car.co.uk/product.php?xProd=97659 if it is mine, it's currently fitted in my 110, so unable to measure it without having my 110 disabled. Quote Link to comment Share on other sites More sharing options...
