Puffernutter Posted July 29, 2011 Share Posted July 29, 2011 Silly question! The nearside headlamp on my 300Tdi has a significant amount of condensation in the headlamp (no corrosion though). The offside headlamp is fine! Is that an MoT failure? Cheers Peter Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 29, 2011 Share Posted July 29, 2011 if it's affecting the beam pattern, then yes. get the hairdrier in there before the mot Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted July 29, 2011 Share Posted July 29, 2011 Hi.Just park it with the headlights facing into the sun. The Sun The Rain and The Air the only things free in life. If only I could find a way to harness these three things, I am quite sure it would be a winner. Quote Link to comment Share on other sites More sharing options...
disco_al Posted July 29, 2011 Share Posted July 29, 2011 if you need a headlamp i've got one here - £15 delivered Quote Link to comment Share on other sites More sharing options...
teabag Posted July 30, 2011 Share Posted July 30, 2011 The headlamps are vented via the bulb holders rubber cap just check that it's facing downwards and is not blocked. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted July 30, 2011 Author Share Posted July 30, 2011 Having now had a closer look.... There is a pool of water at the bottom, so I assume that it is leaking from the top joint. I have a new one coming, so I'll just swap it. When it is out I'll dry it out, clean it up, put some mastic on the top and keep it as an emergency spare. Cheers Peter Quote Link to comment Share on other sites More sharing options...
