Ced Posted July 28, 2006 Share Posted July 28, 2006 What's the best way to install 4 point safety harnesses in a 90 truck cab ? Quote Link to comment Share on other sites More sharing options...
LR90 Posted July 28, 2006 Share Posted July 28, 2006 Lower mounts on mine reuse the existing mounting points. Uppers into the bulkhead top rail with reinforcing. Not sure its ideal though as I'd preffer the tops to be a little higher. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted July 28, 2006 Share Posted July 28, 2006 im thinking of building a hoop that will mount to the existing anchor points on the chassis, and raises in each corner with a vertical bar behiond the seats, only negative thoughts so far is that it will prob reduce amount of rom in cab coz seats wont go as far back, you could always plate the rear bulkhead both sides and fasten through there with an eye to clip the harnesses into? Quote Link to comment Share on other sites More sharing options...
