reverard Posted August 13, 2011 Share Posted August 13, 2011 Hi I just bought a Defender 110 300TDI and discover there is no air filter or hoses connected to the turbo. I have sourced the parts but wondered where the aire filter mounting bracket bolts to. It looks like the engine blck which means I will have to loosen all bolts and retighten in sequence. I cannot seem to find an image without the air filter box attached (which stops me from seeing how the bracket attaches) Any advice would be much appreciated Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 13, 2011 Share Posted August 13, 2011 no need to undo all the headbolts, just the 2 which secure the air filter housing mount. see page 564 for hoses & page 565 for the mounting bracket Quote Link to comment Share on other sites More sharing options...
reverard Posted August 19, 2011 Author Share Posted August 19, 2011 thanks for the help and your response. I wasn't sure that undoing just the two bolts could cause the head to warp....obviously not thanks again Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 19, 2011 Share Posted August 19, 2011 a stone cold head won't warp, it needs heat to do that. Quote Link to comment Share on other sites More sharing options...
reverard Posted August 19, 2011 Author Share Posted August 19, 2011 Brilliant. I have a lot to learn as i havent worked on a car in 25 years but I am keen to learn. Thanks very much again for your help Richard Quote Link to comment Share on other sites More sharing options...
western Posted August 19, 2011 Share Posted August 19, 2011 happy to help, have a read through the tech archive, Les H's 'how to threads' are worth a read. Quote Link to comment Share on other sites More sharing options...
reverard Posted August 20, 2011 Author Share Posted August 20, 2011 happy to help, have a read through the tech archive, Les H's 'how to threads' are worth a read. thanks Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 20, 2011 Share Posted August 20, 2011 To set your mind at rest some more I did the exact same thing about 2000 miles ago, no head problems so far Just undid the two head bolts then tightened as per manual, just as Ralph has said. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 21, 2011 Share Posted August 21, 2011 I thought they were stretch bolts.... Use once... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 21, 2011 Share Posted August 21, 2011 Manual says can be used 5 times if I remember correctly .... maybe it's 6 .... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 21, 2011 Share Posted August 21, 2011 Rave states cylinder head bolts may be used up to a maximum of 5 times. Quote Link to comment Share on other sites More sharing options...
arthur90 Posted August 22, 2011 Share Posted August 22, 2011 A bigger worry might be why has it no hoses and what might it have sucked in without them. Could it be a way of stopping oil from the breather getting to the engine as fuel? Quote Link to comment Share on other sites More sharing options...
reverard Posted August 22, 2011 Author Share Posted August 22, 2011 thanks guys plan to do this job this week I wonder if a lot of carp has been pulled into the intercooler whilst there has been no air filter attached? Quote Link to comment Share on other sites More sharing options...
