Guest Posted August 25, 2011 Share Posted August 25, 2011 Can someone please tell me if I have been dreaming or not? not in general just around this question!! Does someone make a small adaptor to allow you to undo the 1/2 inch diff plug with a spanner? I have a slider plate/protector on my rear diff and it's a PITA to get any type of 1/2 inch ratchet into the bottom plug, after struggling again I am sure that someone had invented a tool/adaptor for this purpose when things were a little tight or am I just dreaming? I seem to remember it was a 1/2 inch bit then a disk/washer and then a bit of metal the other side you could put a ring spanner on. Jason. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 25, 2011 Share Posted August 25, 2011 Ebay or Another Quote Link to comment Share on other sites More sharing options...
Guest Posted August 25, 2011 Share Posted August 25, 2011 Ebay I had seen them but I think they would still catch on my diff guard struggle to get the 1/2 inch UJ socket in or my wrench hence the disk thing. Jason. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 25, 2011 Share Posted August 25, 2011 Sorry added another link after with something that looks smaller. Quote Link to comment Share on other sites More sharing options...
ajh Posted August 26, 2011 Share Posted August 26, 2011 Just jb-weld in an inch of 1/2" keys stock then any 1/2" wrench would be fine. Quote Link to comment Share on other sites More sharing options...
crclifford Posted August 26, 2011 Share Posted August 26, 2011 Jason, If it's the drain plug, wouldn't an 1/2" extension bar do the trick? HTH Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 26, 2011 Share Posted August 26, 2011 With mine I have Qt guards, so I just use a short 1/2" drive extension to get the ratchet to clear the guard Quote Link to comment Share on other sites More sharing options...
Guest Posted August 26, 2011 Share Posted August 26, 2011 Just jb-weld in an inch of 1/2" keys stock then any 1/2" wrench would be fine. I will make something jut thought there was one on the market that I could buy for less cost/effort. Jason, If it's the drain plug, wouldn't an 1/2" extension bar do the trick? HTH Yes its the drain plug but 1/2 inch bar will fit in but the diff guard gets in the way the only tool I can get in is the 1/2" U/J but have to loosen the diff guard first which is not easy!!! With mine I have Qt guards, so I just use a short 1/2" drive extension to get the ratchet to clear the guard I am not sure what my back guard is Its a slider plate fitted to the diff housing by the 3 bottom diff bolts there is some room to get in just not loads. Anyway guys thanks for the reply I must of dreamt the tool although looking around I think I will just fit an X-Plug which has a male fitting rather than the current female plug, guess I will be shopping at Peterborough if Simon is there. Jason. Quote Link to comment Share on other sites More sharing options...
