Blowing exhaust ????
barriesheene
When my manifold to down pipe gasket leaked it sounded like a machine gun when underload, going up hills etc.
I couldn't see a leak but the garage could, and that was the drivers side, so 6 months later when they replaced the auto fluid and had to drop the Y pipe they also had replace the gaskets. Job done
  • 2 weeks later...
Hi, guys. Sorry its been awhile I'm upto my eyes at the moment. UPDATE. Had new stainless exhaust fitted from y piece back. Gaskets changed ,( down pipe and manifold ). It is a machine gun sound which is what made me suspect gaskets but I cant seem to find the leak !. It is down on power tho and I pressure tested the bank of cylinders and the one closest to the bulkhead was reading 80/100 psi while the other three were all showing 150psi. Can the head gasket go from cylinder - out if there are no other symptoms ? No loss of water, never overheats, no signs of water in oil or vice versa. Dont want to get head done if no need but why would I be down on compression in just 1 cylinder ?? Please help.
