100" defender... couple of measurements needed
chrism
Afternoon all
I have a disco chassis which is having a defender body grafted onto it. Would someone be able to tell me how far the front bulkhead mounts are supposed to be from a certain point, either spring mounts or radius arm mounts. Quite a critical dimension as everything else is worked from that. Unfortunately I dont have a defender to hand to measure it off!
Thanks in advance
ok just took a couple of measurements
first one is from the back edge of the spring mount (The bit that the turret bolts on to) to the front edge of the bulkhead out rigger (with the tape measure touching the edge of the main chassis rail. 385 mm.
if you plonk the outrigger on this mark then the other measurement should tally
from the back edge of the outrigger to the end of the thread on the radius arm 206 mm.
hope this helps.
as "Briarston" states.there are 2 bolts at the top of the gearbox x-member,measure 25mm forward from the centre of the front bolt.the rear vertical face of the new outrigger is where it sits.
i'll take a pic of mine tomorrow as i'm building a 100" disco trayback.
