Diablo Posted November 22, 2011 Share Posted November 22, 2011 What's the best way of fixing this? I was thinking maybe some sort of plate either side? Driver's sill: Passenger's sill and in the background you can see the chassis to bulkhead area as well. The rear of the tub to the crossmember has similar problems, though not as bad. Quote Link to comment Share on other sites More sharing options...
landy V8 Posted November 22, 2011 Share Posted November 22, 2011 i'd just pop rivet a piece either side. Quote Link to comment Share on other sites More sharing options...
Mutz Posted November 24, 2011 Share Posted November 24, 2011 Well you have a galv chassis so why not weld it as that would be a proper job, and compliment the chassis. Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2011 Share Posted November 24, 2011 clean the corrosion off & treat with etch primer then use a jointing compound & rivet a repiar plate to restore the strength & original shape. Quote Link to comment Share on other sites More sharing options...
LandyLee Posted November 25, 2011 Share Posted November 25, 2011 Are they prescribed areas , i.e. near seat belt mounts ? if so you really should get the repair patches welded in. If there was corrosion/holing near enough bodymounts then this would be a problem as well. I agree with the etch primer etc. its just some mot testers might object to repair methods. Quote Link to comment Share on other sites More sharing options...
Diablo Posted November 25, 2011 Author Share Posted November 25, 2011 It's the mounts for the sill (proper one, not the decorative bit) to the body and also some ali corrosion where the steel plate on the middle bulkhead bolts to the tubular part of the chassis. Wouldn't risk anything with seat belt mounts, but they're ok. Thankfully my MOT man likes Land Rovers and we've known him for ages... not had a fail yet! (not to say that he isn't safe of course) Quote Link to comment Share on other sites More sharing options...
