jameslwt Posted November 30, 2011 Share Posted November 30, 2011 I have noticed over the last few days that my 2003 td5 has been very rough at start up until I press the accelerator. Otherwise all fine. Then today it would fire but immediately stop - until I kept the key turned and again pressed the loud pedal. Again it's been fine all day since then. I also noticed a whining/high pitched buzzing from the rear of the vehicle - so this makes me think it's a pump issue. Has anyone else got any other ideas before I order a new pump? Many thanks James Quote Link to comment Share on other sites More sharing options...
disco_al Posted November 30, 2011 Share Posted November 30, 2011 sounds like the pump to me - common ish td5 problem Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 5, 2011 Author Share Posted December 5, 2011 Replaced the pump, but still got starting issues as before. Could the fuel pressure regulator also casue this, as I understand that is also a common issue? I'll have a look for diesel leaks later on. Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 5, 2011 Share Posted December 5, 2011 Fuel pressure pressure regulator leak will cause poor starting as the pump will have to work harder to get the fuel system up to pressure in order for the engine to start. Easy enough to check for it leaking though. Les. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 5, 2011 Share Posted December 5, 2011 "Whining" and "gurgling" fuel-pump noises plus starting-issues were the symptoms of failed copper injector-seals on my 2001 TD5 Defender. Fix this quickly - or the combustion-gases and carbon that get past the seals will trash the fuel-pump. And that's a £500 fix. The seals themselves are pennies each, and a couple of hours labour to replace. --Tanuki. "Badgers are never part of the answer but always part of the problem" Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 5, 2011 Author Share Posted December 5, 2011 Thanks guys - I'll look tomorrow Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 5, 2011 Share Posted December 5, 2011 I'm with Tanuki on this. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 6, 2011 Author Share Posted December 6, 2011 Well there's no evidence of any leaks from the fuel pressure regulator, so I think you might be right. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 6, 2011 Author Share Posted December 6, 2011 Just been to talk to local land rover garage man to get him to change injector seals (didn't fancy doing this one) and he immediately said 'air flow meter' - and of course this is a quick job that I can do myself (ie doing himself out of a job). Now I'm not sure what to do! Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 6, 2011 Share Posted December 6, 2011 Rubbish,nothing to do with AFM, if you disconnect it the ecu will run default values instead.It does not affect starting and the ecu wont look for a value from it till the engine gets to about 500 rpm,even then if its a very low output it will just be gutless.I see many running around with them disconnected,they dont make a great deal of difference. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 6, 2011 Author Share Posted December 6, 2011 And another garage (well known with a good reputation) has suggested I change the injector harness before anything else. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 7, 2011 Author Share Posted December 7, 2011 Just whipped the ECU out and sure enough it has oil around the connectors.....so guess I'll start with that Quote Link to comment Share on other sites More sharing options...
