CJRH Posted December 8, 2011 Share Posted December 8, 2011 Every now again the water in diesel light comes on but only flashes on and off. When I had the Disco serviced 2 months ago I mentioned this and when they changed the diesel filter there was some water in it. Is there a way of draining off the water? Disco 2 Td5 January 2003 Cheers, Chris Quote Link to comment Share on other sites More sharing options...
minimaquinas Posted December 8, 2011 Share Posted December 8, 2011 hi chris there should be a plastic drainer on the bottom of the fuel filter hope this helps brian Quote Link to comment Share on other sites More sharing options...
CJRH Posted December 8, 2011 Author Share Posted December 8, 2011 Is that on the fuel filter under the rear wheel arch or in the engine bay? Cheers, Quote Link to comment Share on other sites More sharing options...
jameslwt Posted December 8, 2011 Share Posted December 8, 2011 Under the rear wheel arch - remove the wiring plug and unscrew the sedimenter at the bottom of the filter - place a bucket underneath, until pure diesel runs out - shouldn't be much. Quote Link to comment Share on other sites More sharing options...
CJRH Posted December 8, 2011 Author Share Posted December 8, 2011 Cheers for that, job for tomorrow. Chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 9, 2011 Share Posted December 9, 2011 Those lights are always crying 'wolf'. Just disconnect it and that is that. Quote Link to comment Share on other sites More sharing options...
bear Posted December 12, 2011 Share Posted December 12, 2011 I've got the facelift model (2004) and the sensors were not fitted as standard. Griff Quote Link to comment Share on other sites More sharing options...
