need4speed Posted December 23, 2011 Share Posted December 23, 2011 Ive already got a windscreen wiper motor, though its untested. Just in case i need to change it i was wondering if all defender wiper motors are interchangeable? The old 110 parts book doesnt show any variance in motors but looking through various online parts stores, there seem to be 2 or 3 different types available? My new wheel boxes will be td5 ones but i know my motor definately isnt from a td5 - does this matter? Quote Link to comment Share on other sites More sharing options...
simonb Posted December 23, 2011 Share Posted December 23, 2011 Basic motors are certainly the same from series 3 to Td5. You may neeed to swap over the main gear and crank if fitting a series motor and vice versa. If you are fitting TD5 wheel boxes they should work with an older motor/cable. Quote Link to comment Share on other sites More sharing options...
Burko_uk Posted January 2, 2012 Share Posted January 2, 2012 The difference is the angle the motor is bolted onto the bulkhead at, and thus the shaft and tube that comes off it. But if you buy the motor on it's own they are all the same. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 2, 2012 Share Posted January 2, 2012 The motors are all the same (in that the motor part is interchangeable). However, unless you buy a new late TD5 motor you will need to change the gear and crank if using earlier motors in order to have the correct gearing for you later wheel boxes. Remove the gear cover from the motor (4 small bolts) and if it says 113 degrees on it then it will not be suitable for the larger TD5 wheel boxes and you will have to buy a new gear. They are not expensive, I think I gave about £15 for a genuine one. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 2, 2012 Share Posted January 2, 2012 http://www.reedx.net/landrover/maint/wiperparking/ pics here of how to change the gear (though this is a refurb not a change of ratio) Quote Link to comment Share on other sites More sharing options...
