James NZ Posted December 28, 2011 Share Posted December 28, 2011 (edited) Hi everyone, Merry Christmas to you all. Just been up the hill (600metres) fossicking around old mines and on my descent noticed warm water trickling down on top off the carpet, roughly in line with the end of the centre console where it goes under the dash. Would this be roughly where the heater is? Please note it was warm here today (about 25c) and the air con was getting a work out and was in use going up the hill which is a slow twisty climb. Just checked the radiator and the water level has dropped, bugger! We are on chrissy holidays and my car is getting quite a lot of use on tracks etc so I need to sort this. In fact I will probably just bypass the heater for the rest of the trip. Is it a major to get the heater matrix out. Sorry for all the questions, I'm using the mother in laws computer so don't have access to my rave files and other info etc. My car is a D1, V8. Here is a wee picture from yesterdays trip to the river. Forgot to add that the water is dribbling on both sides of the transmission tunnel but more so on the right. Cheers, james NZ Edited December 28, 2011 by James NZ Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted December 28, 2011 Share Posted December 28, 2011 If it is the heater.and with a bit of a contortion you may be able to see/feel the pipes as they come into the cabin to the left of the clutch pedal (as you look at it) - - it is a sod of a job. I did it about 12 months ago and when they build a D1, you have a metal body, then they install the heater, then everything else It is a total dash out job. As a first timer, took me over a day and a half. Cheers Peter Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 28, 2011 Share Posted December 28, 2011 If it's 25c and you dont need the heater, connect the flow and return pipes back to back before they go through the bulkhead. This will isolate the matrix till you get back home. Not sure where the pipework is on D1, a grownup will be along soon. Quote Link to comment Share on other sites More sharing options...
James NZ Posted December 28, 2011 Author Share Posted December 28, 2011 Hi guys thanks (I think ;-) ) for the confirmation Peter. I rather dreaded that may be the case. As my car is a daily driver this is going to take a bit of planning. pete3000, yer had already decided that may be the best fix for now. Just watched the news and the weather man has said that the Nelson (South Island, New Zealand) is in for heavy rain for the next few days, guess where we are heading tomorrow Cheers, james NZ Quote Link to comment Share on other sites More sharing options...
zoltan Posted December 28, 2011 Share Posted December 28, 2011 It you simply want a get you home option, chuck an egg in the radiator (or mustard) It's an old skool get you home which does work for a while on small leaks Quote Link to comment Share on other sites More sharing options...
peterdon Posted December 28, 2011 Share Posted December 28, 2011 I'd go for the heater bypass. Some of the 95 Disco's have a valve that both flow and return pipes go into just before the bulkhead - see pic attached. This is supposed to cut off the heater whilst the engine is warming up. If you've got one you can tape/tie it closed. Job done. Quote Link to comment Share on other sites More sharing options...
