"proper" wiring diagram for a discovery needed please
andy2986
Hiya,
Could someone help me out or point me in the right direction please.
I need a proper i.e. not Haynes, wiring diagram for a 1997 V8 Discovery.
Ive got a frustrating fault on my Disco, tried using the Haynes diagrams, but it would appear to not be detailed/accurate enough
Thanks
Andy
The LR RAVE info has wiring diagrams, but they are more of a block type not like the line for each wire type, you will find a link to RAVE in the Tech Archive index under Manuals or at the top of the request for part numbers forum.
easier to follow than the haynes colouring book though, with the proper wire colours and also pictures for the conectors and the locations as well all linked by code numbers
Thanks guys, I had started downloading them, I need to go and get some blank CD's to burn them on so I can see them....
If you download MagicDisc you can create a virtual drive and run the ISO on your computer.
Hope this helps.
