Mutley Posted January 3, 2012 Author Share Posted January 3, 2012 Jesus! Timing kit (Genuine) comes in at a fancy price! I guess that this is the best way to go? But have found an O.E.M Bearmach for half the price is this worth considering? Also found PR2 ALLMAKES OE at simular price, so if either of these are any good, which one should I go for O.E or O.E.M? If I'm gunna do this DON'T want cheap and nasty.......I want CHEAP and GOOD! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 3, 2012 Share Posted January 3, 2012 Bearmach kits are better than genuine in my opinion, and I always use them. The belt is Dayco and the crank sprocket is one piece, so no seperation problems as was common with the genuine item. Les. Quote Link to comment Share on other sites More sharing options...
RILEY Posted January 3, 2012 Share Posted January 3, 2012 Dont forget the "o" ring behind the crankshaft gear !!!!!!!!! ask me how i know ! it does'nt come in the belt kit (buy a gates belt ) rolls-royce of belts, fit and forget (as long as everything else is ok ) Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 24, 2012 Author Share Posted January 24, 2012 Ok then got pretty much all the tools for the job..... So i have been reading a few previous threads on this matter and a NEW QUESTION has now come up!!!!!!! As I have an early 300Tdi (M reg 1995)......Do I need to get the MODIFIED Timing kit or am I ok just to get a Bearmach timing kit, Which is OEM ??? Cheers guys Mutley Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 24, 2012 Share Posted January 24, 2012 If your old timing belt hasn't been rubbing on the timing case to such an extent that it's visibly thinner than the new one, then the alignment isn't a problem and a standard 300TDi timing belt kit will be fine. Les. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 24, 2012 Share Posted January 24, 2012 Dont forget the "o" ring behind the crankshaft gear !!!!!!!!! ask me how i know ! it does'nt come in the belt kit (buy a gates belt ) rolls-royce of belts, fit and forget (as long as everything else is ok ) Why a gates belt? I've got the shredded remains of one of there fan belts in my lock up, I only bougt it in the summer of last year. Dayco is OEM so in mine and alot of other peoples opinions, Dayco all the way. Quote Link to comment Share on other sites More sharing options...
